Forge hose for intercooler
Hi all . I found a guide how to fit in the intercooler but his hose looks different to mine . He has a metal plate for his MAP sensor to bolt on , mine looks like it pushes on and a jubliee clip to tighten it in . Is this right ?
Here is mine.
You can see that the Forge Hose is a flexible one that has a smaller hose and that is where the MAP sensor pushes into. The Forge kit should come with a small metal plate that the MAP sensor is screwed to and then that plugs into the small hose(not if you have a new FMIC the small hose is not as long as the one i have in pic below.
Also this is Forge own fitting instructions you can get from their website.
http://www.forgemotorsport.com/media/FMSKOFMIC.pdf
hope it helps
hi , yes this helps thanks . Not got the plate the sensor screws on . They are new hoses just when i saw the instrutions thought they sent the wrong ones . Time to start stripping the front end now :)
