Turbo from a 225 Audi for a VRS
Would the turbo from a TT 225 for straight onto the VRS engine, or does it need some other modifications?
Many thanks.
Im doing the K04 conversion myself, you will need
K04 023 turbo
K04 manifold
386cc injectors(fromm std 225)
Oil and coolant feeds
3" MAF
K04 turbo inlet hose
EGT sensor if you are going to retrofit
ECU from 225 car(or custom map if not fitting EGT sensor)
Modified loom for EGT
Gaskets etc
Custom downpipe or relentless one with modification
It is a big job but with 3" DP and 3" TIP 275-280BHP is possible if you have a FMIC, good intake and a decent map.
Hope this helps mate
Just buy a hybrid cheaper and give better power ;-)
That sounds far easier reading the above, how much are you looking at for a Hybrid?
Edited by DKB69
700 for hybrid
Needs
Injectors
3 inch maf
Map
But this is if you already run front mount decent exhaust etc etc
Would the K04 innards in a K03 work?
That is effectively what a Hybrid is. That is why they are called Hybrids as they have a combination of some parts of the K03s and some part of either a KO4 or other variant.
Hybrids all the way.
Easier and better power gains.
From whatnive heard and read the ko4 conversion is never as good on the auq enngine as it is on the bam.
Plus the hybrids have bigger internals than the ko4. I have a cr turbos hybrid with pritty much everything. Its got rs6 internals.
Iwhen i was after getting one they were £850 ish for your own turbo to be rebuilt but then they have you as no exhaust housing is not cracked so they add more on for another.
