Slimy water intake.
Hi, I have a Nilfisk C110. Just recently there has been a problem. On switch on, the pump just whines and no jet.
Traced this to a blocked inlet filter, its all slimy. I have tried prising it out, but no joy, don't want to use too much brute force and break it - sods law that will be an unavailable part.
Any one know if this should/will come out? If so, is there a trick?
I have managed to scrape out enough to get a jet, but its not brilliant.
I did consider a chemical to dissolve it but thought better of it.
So thoughts or suggestions anyone?
TIA
Nick
Have you posted up something on DW as I think that will be a better target market?
No, thought plenty of people on here have one?
Will give it a try
Will give it a try
Granted but I think you will get a much quicker response on DW with approx 60,000 members specifically on the forum for car 'cleaning' related topics....... :)
  • 2 months later...
No joy there either, I rfm and it says to check the filter before every use so somewhat surprising, or no one else rfm's.
Anyway, as we did have a few warmer days, I took it outside and had a closer look. The filter came out fairly easily once I got some decent pliers on it and now pops in and out like a good 'un. Left it overnight in bleach as it was covered with slime, a rinse and now all is good.
Even got time to give the bus a wash.
Thanks for that Chris, I'll drop them an email in the AM. I 'll get a couple of spares as they are quite fragile.
