Anyone got information re Felicia Laurin & Klement
I cant find any information re electric windows or wiring diagram
hi there i mite be able to help you out what do you need to know on this as i fitted eletric windows to mine
It already as electric windows just cant get them to work and the wiring makes no sence and no mention in the manuals I've got
right do you have the two wire in yours blue/black from motors if so i can help you fuse 18 is the electric window fuse amd there is a relay behind glove box let me know if you need more info
Edited by uma1998
Thanks I will have a look in the morning got the door panels off see blue and black coming to window motor
right i can help you get these fixed got same kit fitted to mine got kit from skoda old stock for mine and my old Bohemia had same one. do your switchs light up when ignition on....
fuse 18 is for them and theres a relay behind glove box but on top right hand corner will have white plug on it thats the relay it should click when ignition switched on
if needed can get the fitting instructions off wireing but there is only 3 wires that feed power from car to this loom red LIVE / blue/red SWICHED LIVE brown earth
i can get pic's if needed
Edited by uma1998
That's just brought back a memory of my Felicia L&K.
I fitted to kit to the leccy windows so that when you locked the car the windows closed themselves.
I also fitted an automatic light kit with coming/leaving home function.
Loved it!
i got that on my car played about with alarm to do it put works well with HID's
Thanks will have a go at week end to dark after work.
if you get stuck i can help ya on the phone
