central locking a skoda pickup
is it an easy job?
Yes. Hth.
I agree. Hth2
Yes, very. HTH³
what i should of said is , what do i need to add central locking to my pick up ?
and does anyone nowhere i could pick these bits up ? whats the correct names of these bits etc etc,
go to maplin the do a complete kit for around £30 the intructions arent the best but its pretty self explantory, you may be able to replace the parts with standard parts from a felcia with central locking aswell, i cant see why not but i done mine with the maplin kit, plus the kit comes with 4 motors so your left with 2 spare if 1 ever gives up :)
OEM Felicia kits are quite rare now. The worst part was feeding the connector through the bodywork between the door and the chassis. I would humbly submit a scouting around the local breakers yards. You might be lucky enough to find central locking and electric mirrors (electric mirrors is a bigger loom, but worth it - IMHO )
The OEM kit has a connector that goes the accessory connector behind the stereo, and a relay, as well as 4 motors.
There's also a remote option for the OEM kit too, but that's even rarer.
A 3rd party kit would probably do the job just as well though.........
http://www.ebay.co.uk/itm/UNIVERSAL-REMOTE-KEYLESS-CENTRAL-DOOR-LOCKING-KIT-WE-/360551938532?pt=UK_Car_Accessories_Safety_Security&hash=item53f291f9e4
Yes i would suggest looking for a glxi model hatchback and take the lot from one donor car.. I seem to remember that the dash is already wired up for it, iirc it uses red connectors behind the kick panels on the base of the a pillar? Anybody confirm this? You need the motors from the doors plus the door loom, the 'brain' plugs into the connector behind the dash like stated above..
i can get all you need for conversion as i breaking another felicia :-(
Edited by uma1998
thanks for offer UMASLXI1998 iwill defo get back to you on this ,
i have just found more welding in the rear tub that will take up time and more money , but we will speak soon , cheers steven
when its done underseal it all will last that extra bit longer years
