What Does This Mean
I have the EML on in my '06 Fabia Vrs 1.9 and VCDS is telling me
19557-Motor for intake manifold flap (v157) open or short to ground
p3101-35-10---intermittent
Does anyone know what this means or what I have to look at?
Many thanks
It could be on the aircon/heating motor flaps under the dash, if it is if you go into avac ? and reset the motor flaps, it happens a lot and usually the heater sticks on. To be certain have a look on the VCDS website. cheers - Stuart
No that's nothing to do with the aircon etc.
Thats the little flappy think in the intake manifold on the engine.
Quiet common to stick/fail.
Phil
V157 manifold flap is I believe the flap valve on the EGR.
HVAC flaps wouldn't put the EML on I don't think.
Ah yes. The anti shudder valve? Or the actual flap that lets the exhaust gassess in?
Phil
Phil
Anti shudder I think.
Think you're right as that's motorised on the BLT engine.
To the OP, does the car/engine shake a lot when you turn it off? It should be very smooth and just shut straight off.
Phil
I think you can test the flap in the "output tests - 03" section.
I only know this as when I was playing around in there a while ago I accidently shut down the engine when I activated that flap!
