mud flaps
hi all got a blackline.forever washing it.whats the thoughts out there for blue colour coded flopy flaps for the winter.same idea as rallt cars use
They look so chavvy!
only for winter use.cant keep washing it.its not mpg its buckets of water per mile
Agree with the above they'll look shoite. You've bought a great car don't spoil it...IMO... You can get both pairs of Skoda ones for about £43 as a set. the fronts go on easy peesey, you just have to put wheel on full lock. The rears are a bit of a pain as they arn't meant for the vRS (so skoda will tell you they don't make and for the vRS) as the rear wheel arches are slightly different, but put em in a bucket of hot water to soften them up and they'll go on ok- I've got a small gap in mine at the bottom and put some black silicone between the rear flap and the inner arch because there was a small gap.
The other bummer is if you've got the compressor/gunge bottle you'll have no brace and jack and they are a lot easier to fit wit the rear wheels off- I tried to do it with the wheels on and gave up, got the trolly jack out and whipped the wheels off. They don't keep all the crap off but are better than without anything and look quite nice. The rears are square in profile at the bottom, same as the front. if you want to save a few quid you can buy the fronts (they are classed as accessories) and the OE rears that are rounded as the OE rears are much cheaper than the square 'accessories'. You can see the OE ones fitted to most other Octy's if you want to see what they look like
forgot to add there's at least 1 thread in the octy II section on this that gives the part numbers if you want them
