Mk2 golf 1.8T conversion no communication with ECU
Posting this for a mate of mine doing the above conversion.
Engine and loom all in place, fired it up, all running sweet.
He's doing the mk4 dash into the mk2 so the Immo is all sorted etc.
Tried doing a scan as theres a few warning lights so we were going see what was needed to be wired up.
We got no commo between the ecu and VCDS.
The ABS and Airbags ones are fine as we ain't connected all sensors yet.
Anyone got a clue as to why no commo. Probably something really simple that we have overlooked like when the engine wouldn't start it was a fuse lol
Tuesday,29,January,2013,15:13:03:28932
VCDS Version: Beta 12.10.2
Data version: 20121222
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 259260km/161096miles
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 00028
VCID: 3F86D5E03D0CB8E6B17
4 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-00 - -
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
35-00 - -
01312 - Powertrain Data Bus
37-00 - Faulty
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 921 A
Component: A4-KOMBIINSTR. VDO V16
Coding: 05442
Shop #: WSC 00404
VCID: 234E7990B1A4FC06B5F
Subsystem 1 - Part No: IMMO
Component: IDENTNR:
IMMO-IDENTNR:
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0E4C6DCB0D2979EF8D
3 Faults Found:
is the immo fitted at the mo (with the clocks) this would stop it talking if not
Yep. All good on that side of things. Fire's up running sweet
