Porsche brakes
ive been offered a set of porsche brakes from a mate but i want to know if anyone can tell me what porsche brakes they are or anyway of telling what ones they are
sorry for a bad pictures but couldnt really see what i was doing when i was in his loft haha
and if someone is able to tell me what ones they are what sort of money should i be looking to pay? they are in need of a referb
Thanks for any help in advance!
If they need refurb they aren't worth a bean.... Porsche caliper rebuild kits cost a small fortune, before you go buying them measure the pistons and do the maths, there's quite a lot of important science behind choosing the right caliper to match them to the existing master cylinder.
I think they're 911 rears. Not sure if they're a straightforward fit on VAG platform, I *think they work in conjunction with 330mm discs.
if they are rears, you need to be careful, as they have smaller pistons but that don't work well on some vag mc's iirc, look at what tom said above, choose carefully.
There are plenty of brembo gt kits or lcr kits (basically the same) that come up for sale for under £500 all in.
The paint job on them looks dreadful, covering loads of bits.
If that's the attention they got, I'd leave them well alone.
they have literally painted everything, inc all rubber seals by the look of it..
don't be led by the name, they are just brembos, that are fitted to a huge amount of oe cars
True but the fitment can vary accordding to how the were fitted to the car they were made for and the availability of the bracket/carrier for the desired application.
yes thats very true, there are lots of differences between calipers, i was just trying to warn adam, just cos it says porsche doesn't mean they are the best, have seen people put porsche decals on 7 series calipers, basically there are a lot of four pots out there. Its def best to wait and find the right caliper for the job!
thanks for all the help guys! i know they looked awful but thought its worth looking into ive been speaking to couple different people and pete (group1rs) has helped me figure out these are 996 rear breaks as teflon tom has said they will cost s fortune to sort out so i wont bother i will wait until i have some money to spend and get the right ones for the job :)
Thanks again for the help!
out of interest, how much you seeing the right calipers for, as i have a set of brackets for brembo fitment in my garage that am tempted to use?
erm well ive been looking around and it looks like they are around £500 for fully refurbished and not to sure about used ones as i cant seem to find any might be worth you having a look as i can be known for missing things when searching the web! haha
yes i will have a look when i get the chance, usually anything between 150-250 for calipers iirc
