Towbar coding
It was supposedly the time taken for certain lights to go out, (I think) but has never been confirmed.
  • Replies 52
  • Views 12.3k
  • Tow bar coding enables: bulb failure system to be extended to trailer bulbs. uses the bulb failure system to show when a rear flasher isn't working on the trailer, as required by law. allows the fl
  • Hi RoryRover & welcome Vehicle data is given in coded form on a stuck-on label in the Service Schedule booklet. The code for trailer hitch preparation is AHV - if your label has that on it, then
  • As Arkaig says the quickest way to tell if you have towbar prep is to check under the rear bumper where there will be a removable plate--it needs a good tug to get it off though. Please see the excel
Sorry to resurrect an old thread!
I had the tow bar fitted on our Yeti by the supplying dealer before we picked up the car after we selected "Tow bar Prep" as a factory option.
I have connected the trailer today and i'm not sure that the coding has been done correctly - some functions work, but not all.
Bulb failure system to be extended to trailer bulbs - This works because we had an indicator out
Allows the flasher ECU to accept the additional load of the trailer flashers, without changing the flasher unit as normally required - All OK now bulb is fixed
Switches off the car rear fog lights when the trailer is plugged in - This is happening
Switches off the rear parking sensors when the trailer is plugged in - This isn't happening
Extends the alarm system to sound if the trailer is unplugged when the alarm is set on the car - I haven't tested this!
Enables the in-car display to show the trailer when reverse is selected - This isn't happening
Activates a trailer stability programme in addition to the car one, when the trailer is plugged in - Is there anyway to know this function is working?
So, is it possible to only have some of the functions working?
That sounds a few bytes short of a proper coding. :giggle:
Fred
It was done by the supplying dealer  - I won't shame them as overall they have been pretty good and I'm sure they get it sorted.
I'll let you know how I get on!
Cheers all
