Injectors
Hi Guys.
more questions.... :D
Will the injectors from any PD130 engine fit others? Like from a Golf to a Skoda, or are they different? Even differences in the ASZ and BLT?
Many thanks.
as far as I know all PD130/150 injectors are the same
BLT are different to ASZ. AWX are also different.
They can be diffrent depending on what engine. Code u have but most pd150 injectors for into the pd130
My understanding was all PD130/PD150 transverse injectors were the same, and only the AWX ones you mention from the longitudinal engine flowed around 5% less than their transverse counterparts.
When you compare the duration maps of a ASZ and BLT and also the 2 pd160 engines you find the later engine require a longer duration to meet the same fuel request. I believe it's the nozzles that's different.
Yes you are correct it's just the nozzles that are diffrent allowing higher flow rate
