Hand brake slider mechanism
Just a heads up that I have just had the hand brake slider mechanism on the Scout replaced under warranty. Apparently in the last month the dealer has had 3 cars with the same problem.
Symptoms was progressively stiff action.
Mark
A fairly common issue, or at least one that has been mentioned on here several times.
Well done for getting it in under warranty!
If it's on a jumbo box, mine developed a foldline in it which made it tough to take the handbrake down/off. Took the jumbo off, turned the slider 180 degrees, job done. ;)
