Bolero Radio for Octavia
Just upgraded to a Columbus from my Bolero so it is now available.
It was fitted to my 2006 octy which I had to upgrade the can gateway to prevent the battery drain issue. So please check before buying.
It is in good condition and the sound quality is much improved over the Stream I had.
I am looking for £180 inc postage.
Pm me if interested.
Forgot to mention it comes with code and original instruction manual
I may be interested but would need a canbus upgrade as well. How much are they?
Would this plug straight into a 58 elegance?
G
G
It should do although you might have to by a single to double ariel adaptor which are a couple of quid on eBay and just plugs in the back. Literally a two second job . What radio do you have at the moment? If its a Stream then it will be a straight swap and can use the same trim piece.
I think you can do it for about £85 pre-coded. Eddie-NL can provide you with a pre-coded one so it is just plug and play. It will take about 30 minutes to replace. You can get them cheaper but you have to code it yourself with vcds if you have it.
Stream mp3 I have just now
G
Out of interest did you have the dull screen issue? (usual when fitting in to a pre-fl)
To be honest it hadn't really noticed.
You wont have had the issue then :happy:
GLWTS
Provisionally sold
