FAULT CODES AND WHAT DO THE MEAN?! HELP
i knew i had a failed abs sensor on my car for a week now as abs light and asr light was on.. knew the breaks was fine as there still all nice and sharp.. so i bought a cheep diagnostic lead and did a scan found out i had two faults found with my ABS which was..
00283 - front left ABS wheel speed sensor (G47)
30-00 - open or short to plus
the second is..
00287 - ABS wheel speed sensor, rear right (G44)
35-10 - - - intermittent
could it just be a clean of the rear right wheel abs sensor but replacing the front left?
any ideas please?
Possibly. My old Golf MkIII which I replaced a speed sensor on, the light stayed on for maybe 1- 1/2 miles then went out. That's the only time I've had reason to change one. If it stays on, there's a list on here of VCDS owners, one would more than likely be willing to sort it if it stays on. Search here for VCDS owners map.
HTH
ahh nice one il have tp have a little look at them this weekend i think, they easy enough to change?
iv my own vcds lite programe and cable..
