Three beeps + lots of lights & clicks. Help!
Having a bit of a panic as my car has been playing up. Big time.
Today I finally plugged in the BT module to the cable (I'm doing a lot of running around at the moment and need to keep in touch with people) and now the car won't start...
There are loads of lights on the dash (that don't go out) and three loud beeps from the dash area accompanied by lots of clicking from behind the dash area. Car won't start or even turn over.
Prior to plugging in the BT module, everything worked fine as I had to move the car on the driveway this morning. I still have electrics - interior and exterior lights, stereo, but can't start the car (it's an '07 pre-FL).
I've checked all the fuses (all OK) and am just going to disconnect the battery for 10 minutes to see if it resets.
I did a VCDS scan prior to plugging in the BT and everything seemed reasonable (at least no unexpected fault codes). Now I have lots on virtually everything.
Help, please. I need to be able to rely on my car as I'm all over the place for the next few weeks. Any advice gratefully appreciated.
Battery is flat. On my way to work. I'll explain more in A bit
Thanks - I'll await more.
That does fit with the stereo going off automatically (I had it playing whilst moving some trim) and the dash display resetting itself. Although I'm confused as to how everything else seems to work.
Had battery disconnected for 20 mins and reconnected it with same problem. Although it looked 'normal' until I tried turning the key. Then I got the dash lights and clicking noises from behind the dash display and also the glovebox.
VCDS scan after reconnecting the battery and trying the ignition (although the Terminal 30 problem flagged up in an earlier scan in '01: Engine' seems to have disappeared...
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LD HW: 03G 906 021 LD
Component: R4 2,0L EDC G000SG 8514
Revision: --H06--- Serial number: SKZ7Z0G4110335
Coding: 0000072
Shop #: WSC 73430 790 00000
VCID: 6CDD3D444FBDA778ED4
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F87BA086E4BECE0186
2 Faults Found:
57344 - Unknown Error Code
Unknown - 015 - - MIL ON
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1Z0 820 047 D
Component: Climatic PQ35 010 0301
Shop #: WSC 00000 000 00000
VCID: 346DE524570D3FB8F54
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004766802
Coding: 81880F011004140000110D000000000000097F075C0000
Shop #: WSC 73430 790 12345
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 090207 022 0601
Coding: 00057271
Shop #: WSC 73430
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 5.15 V
OFF
ON
OFF
OFF
OFF
00154 - Windshield Wiper Motor; Passenger Side (V217)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 9.60 V
OFF
ON
OFF
OFF
OFF
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 9.60 V
OFF
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 9.25 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
Component: PARKHILFE 8K H06 0006
Revision: -------- Serial number: 66541011300242
Coding: 100002
Shop #: WSC 12345 123 12345
VCID: 4183BCF0D8BF9A106E2
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:27:09
Freeze Frame:
Temperature: 4.0?C
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD11NW3N
Coding: 0020788
VCID: 3D7BC0006447FEF00AA
1 Fault Found:
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenks‰ulenmodul 036 0070
Coding: 0000042
VCID: 74ED2524178D7FB8354
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4110335
Coding: 0003401
Shop #: WSC 33708 000 1048576
VCID: 3669DF2C41712DA8CB0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:16:10
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:16:22
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 191210F2000277
Coding: 352303
VCID: 3065E9346315039891C
2 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 10:55:56
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:14
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680 A
Component: RNS-MID H41 4024
Revision: AB001001 Serial number: SKZ6Z7Z5703265
Coding: 06000402040100000000
ASAM Dataset: ------------------------- ------
VCID: 2F67EA487E2B1C60886
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:06:33
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:50
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 10:57:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:14:42
Freeze Frame:
Fault Status: 01100010
Fault Priority: 5
Fault Frequency: 9
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:13:10
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 212
Mileage: 195992 km
Time Indication: 0
Date: 2000.00.00
Time: 10:57:10
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
VCID: 3875D1144B65DBD8D9C
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 73430 000 90108
VCID: 356BD8205C7726B0C2A
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 89801A085283007F0004850540085F96907CA0
VCID: 830FF6F8C223C800BCE
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
4 Faults Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:16:05
Freeze Frame:
Fault Priority: 4
Fault Frequency: 28
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 4
Fault Frequency: 6
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:18:22
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 3973D410706FC2D0262
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 212
Mileage: 195992 km
Time Indication: 0
Date: 2000.00.00
Time: 10:57:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:06:33
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:50
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 10:57:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:14:42
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 212
Mileage: 195997 km
Time Indication: 0
Date: 2000.00.00
Time: 12:13:10
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3777D228467BD4A0D06
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660271852
Coding: 0A00000100000101
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_SK35.rod
VCID: 346DE5249F0D3FB8F54
4 Faults Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 184313 km
Date: 2000.00.00
Time: 11:32:20
13635840 - Supply voltage
U1011 00 [000] - Voltage too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 184313 km
Date: 2000.00.00
Time: 11:32:20
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 184313 km
Date: 2000.00.00
Time: 11:32:21
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 252
Mileage: 195997 km
Date: 2000.00.00
Time: 12:19:44
It does look like the battery is the problem.
Sent from my HTC Vision using Tapatalk 2
:whew:
The little window on top shows black (as it should).
Think I need to get it tested and replaced if necessary: or is there a possibility of a more serious fault? (bad earthing?)
Car is on 120,000 miles and I don't have any records of the battery being changed (certainly not in the three and a half years I've had it).
Right then,
I was carrying out some simple coding on my fathers '59 plate Octy II (comfort indicators amongst other things) and this kerfuffle ensued
Dad uses auto lights, and it transpires my nephew had also been playing with his interior lights. We were working on the car for about 30 minutes with doors open and ignition turned one notch for VCDS to recognise the car.
The upshot was one flat battery!! As you couldn't start the car, clicking (a lot) and dash lit up like a xmas tree, xenons flashing all over the place etc.
Called the RAC and battery was way below half power. Chappie put it on charge for about 40 mins and it was upto 3/4 charge and enough to start the car. Took it for a drive for about an hour and it's been fine since.
Didn't half scare the crap out of me though.
So re-reading your post, is your BT module draining your battery? or as you say it could be that the stereo being on has drained it just enough for it not to start :(
The BT module (although new to me) was only plugged in for a few minutes, but the doors had been open and the stereo on for 45+ minutes. So most likely the latter that has caused the problem.
Thinking about it, I have CHL activated so the lights would have been on as well while I was running the scans.
Hopefully you are right and a charge and long run will put it back to 'happy' status again.
Thanks for the advice and support guys. Appreciate it.
But like Jonny5ive in the post he linked to:
I'm puzzled as to how the charge drops so rapidly???
Especially as I have done similar things relatively recently...
61Ah battery to get tested and charged up.... Quickly (tested, not charged that is)!
Thanks for the help people.
See! There's the problem, why do Skoda fit a 61Ah battery to a diesel? Guaranteed not to last long, could do with another 20Ah really.
Cause they're cheapskates.... SWMBO Seat 1.9PD has a 72ah. My BL 61ah ...bonkers. Guess they don't care as long as it gets past the 3 years warranty/skoda assist period. On a slightly different but related topic it's the same with golf trollies- yes I'm sad. They come as standard with 18 hole batteries and last 2-3 years if you're lucky, I boughht mine with a 36 hole version whichwas more expensive but is now 5 years old and is still going strong. Guess it's the same with the Octy battery as SUK look to save a few quid at our ultimate expense
Would a 77Ah Bosch one be a good choice then?
If it needs replacing - which it probably does...
Would be a much better choice than a 60Ah one
Providing it fits I'd go for the bosch, unless you intend getting rid of the car in the next 2 years. If you are you might be better saving your money as the next owner would get all the benefit?
cheers
Ade
Conclusion = baterries are very poor power wise on the Octavias.
Edited by alberg
Agree the original batteries are under powered. I'll be changing mine soon to a more powerful one.
I had exactly this issue with the old 61 Ah battery. Was prob on way out, but I flattened it with it plugged into vcds with ignition on for 20 mins. Scared me too until I realised it was a flat battery. Got me an 80 odd ah one to replace with 5 yr guarantee from ecp, 60 quid with the briskoda discount.
Adam
I have just replaced the original battery on my 09 Octavia CR VRS with the 77ah Bosch battery from ECP, Fits tray ok and covers can be refitted over battery. 13mm socket for securing bolt , 10mm socket for terminal connections. Clock and mileage trip will reset to zero , steering wheel and esp light on, these reset when engine started and steering wheel turned from lock to lock.
Thanks to all for the advice and reassurance. You were right.
Battery was on charge over night and seems to be OK for now.
Will get it tested when I have a chance and replace it if necessary as I can't be risking being stuck anywhere at the moment....
Good good. Pleased its sorted.
Appreciate the rated battery is often considered low but I have a 2006 PD140 with a 61ah battery and it still starts first time hot or cold so It can't be all bad.
Car is garaged but does relatively low miles for a diesel
As always with these things a few will last well but many won't.
The op I believe has also retrofitted quite a few extras which iirc would lead to a slightly higher rated battery if fitted as standard (my pd140 has a 70Ah battery)
