Audi a3/tt quattro 180 downpipe fit on my4x4?
Hi guys I just wanted to know if the audi a3/tt quattro 180 downpipe would fit on my octy 4x4? It's the same engine turbo and heldex system? Thanks
If this item states it fits the A3 Quattro then yes
ps
If this is a stock A3 Quattro downpipe, it'll be the same as on an Octy 4x4
It's a 3" after market for a3/tt quattro? :)
how much it costing you is it new or 2nd hand
it look like it would im also vey interested in it as the flexi has bust on my down pipe on my 4x4 i think we might just have to cut the flange off the end the get it to fit our systems and just use the oem joiner
I think it will fit straight on, the a3/tt got same turbo engine ect I think I direct fit
we havent got a flange with bolt holes to join it to the middle section we have got a compresion joiner
Oh right I understand.. Like the 90 bend bit?
Sorry my bad read it wrong, if you look at the kit it's 3 parts it comes with a joiner ;)
Included 2.15" adaptor allows fitment of any cat-back
oh yes your right didnt spot that might go and pick one up tommorow cheers for that as they wanted 75 pound for a aftermarket normal one
Ok mate, let me no if you get one.. Are you going to use the decat pipe? You should see big improvements
decat does make a good improvement well it has on all my vrs s
  • 3 months later...
did you ever buy the downpipe and fit it ?
i didnt get one
i might take the plunge and buy one and do some pics if fitting goes well
I can confirm this fits was a bitch to fit on axle stands but makes a huge difference and im not running remap yet
not gr8 pics quite hard on axle stands lol. tips for fitment disconnect front prop dnt remove u can move it out the way enough. fit the front lambda sensor after fitting the downpipe as it does not get through the gap with the sensor fitted. oh and u unclip the front heat shield and shimmy it towards the back of the car. BUT SO WORTH IT my turbo spools up so much quicker and boost feels little bit stronger. im sure once i fit fmic and stage 2 it will be mental
https://www.dropbox.com/s/c8eahzpm9hsl17k/IMAG0248.jpg
https://www.dropbox.com/s/zaicfc2wlithyk0/IMAG0249.jpg
https://www.dropbox.com/s/vjhzw23g06kqfe4/IMAG0250.jpg
https://www.dropbox.com/s/pjtaegjlbmjvl3a/IMAG0251.jpg
https://www.dropbox.com/s/melsebf98r422vm/IMAG0252.jpg
https://www.dropbox.com/s/dj1ladjnhr7gfk6/IMAG0253.jpg
Glad the hassle to fit was worth it buddy. Did mine on ramps and still not a lot of room there. And as I had to line up rear exhaust again that was fun.
Sent from my Samsung S3
  • 4 months later...
hi guys great post have you had any problems since fitting ie heat soak , i am looking to fit one on my 4x4 but need to be 100% it will all work , the exhaust builder i am useing in darlington is trying to put me off the idea and that a 2 n a half inch built by him is going to work n fit better but looking at 240+ for that all advice would be a big help cheers
  • 1 year later...
Hi Kyle.
Can you provide more details how to remove old dp from this car.
Do you need disconnect drive shaft?
There is really small place do do anything..
