Dash/fault lights
Hi folks,
The other day I had the 'bulb' light start flashing on the dash, the following day I had the 'curly' light start flashing, I'm being told this could be a glow plug problem? Is this a common thing? The car will be taken to a mechanic friend but I need to use the car before I can get there next weekend
Any advice appreciated
E
First thing. Do your brake lights work?
Hi Phil
Just checked and brake lights are not working
The high level brake light is behaving a little strange, it lights up when I brake when I'm not braking the outer part of the light, left and right is on constantly while the centre remains off
my glow plug light started flashing recently and it was the brake light switch ... not a hard job to do and the genuine switch was £11.30 from tps
I had a rear brake light switch replaced under warranty, it's out of warranty now.
Where abouts is the switch?
Ill go and check the bulbs
Bulbs are fine
just above the brake pedal you may have to drop the drivers side lower dash down but thats not such a big deal....
remove fuse box cover and i think there are 2 torx screws
push the sidelight switch in and put on the side lights the switch should then pull out
unclip wires
undo other torx screws under dash
there is one just under the steering column at top of the little cubby hole
the dash has 2 clips above the side light switch but they pull out easy enough and the dash drops down
you may have to pull off the air con pipe to the can cooler
unclip the block connector from the switch
the switch then twists 90' and pulls out
it will only go back in 1 way
re assembley is the opposite
shouldnt take any longer than 30mins if you take your time
Cheers holmesie,
Just been out to the car again and the battery is flat, car turns over but not enough I the battery to start,
Not sure if this is related or another problem, could it be a faulty glow plug draining the battery?
i seem to remember that the fabia has has common fault on an alternator wire that causes the battery to go flat ... i have not come across this yet so cant comment ..... i suppose the best way to tell is to get the car plugged in to vcds. there is a map in the vcds section you could possibly pm someone near you asking for a favour
I have a mechanic mate who has good diagnostics equipment
Turns out all it was, was a faulty battery and two blown bulbs lol
