Bluetooth control via Columbus
Hi, quick question. After driving a 2011 Yeti, I noticed that you could see the track names and have track control on the columbus of a bluetooth attached iPhone. On my 2011 Superb with a retrofit bluetooth, I can see all the phone details on the maxi dot etc, but the audio only shows as bluetooth audio on the columbus and has no track names and the controls are greyed out (plays audio fine though).
Has anyone seen whether this is simply a coding issue and what the coding should be to enable these features? Or have I got the wrong module?
Any help appreciated,
Martin
You probably need a new module. What is the part number of your current one?
Yep as said new module. Although get it checked by someone with vcds.
Will be interested to see what modules people suggest you should get!
