Silent turbo
Hi I have recently bought a 2008 vrs tfsi. I can't seem to hear the turbo at all even if I have the drivers window down, does this mean its knackered? Seems to go ok perhaps not as quick as I was expecting but maybe I'm a bit tentative to give it full beans? Just would like a few opinions
Give it the beans!
Good advice! What do you reckon to the turbo is silent ok?
its not really supposed to be noisey as standard tbh, you want noise go fit an ITG induction kit, forge spacer
Give it some heavy foot. If you are worried get the fault codes read first.
Ok cheers how to i get the fault codes? And is it costly?
Itll be pretty quiet, youll probably hear the wastegate a bit, particularly if you open the window but it wont be really obvious. If it goes OK i shouldnt worry too much, standard they are mearly quick; they also need a fair bootful to really make them move
Octy isn't an aural car. The engine note is pretty disappointing really. Think of more as a fast family car and not a sports car.
If you need noise you'll probably need to invest in an induction kit and/or a new 'zorst.
Like you i also have a 2008 Vrs TFSI, i have done 20000 miles since i have owned it, and have never heard the turbo, i had it seviced by a VAG specialist last week and he remarked on how well it goes, i would be worried if it started making noises.
I heard the turbo on mine (2006 TFSI) - it's certainly not loud, but it's definitely there! Crack the window open and drive slowly then as you start to come on boost open the throttle a bit and listen out..
Compared to my last car, the turbo noise is quite quiet on the vRS! Last car was a Mondeo ST TDCI......but, in order to hear the turbo significantly, and change the exhaust tone to something decent.....I had a de cat pipe fitted (no need for a cat on a diesel for MOt purposes at the moment) and also a JP Stainless Steel Exhaust. The de cat probably helped the most as you could hear the turbo spool up from the drivers seat, but at the back passenger side - where my son would sit normally, it sounded like a quiet dump valve when you changed gear - probably to do with the trype of turbo (in the Mondeo it was a VNT turbo).
Hmmm....what type of turbo is in the Octy vRS??
The petrols don't have a variable turbo just the diesels.
The turbos on diesels are much noisier. Don't know that the reason for that is though.
Phil
I tried that, window open, lead foot through 2nd and 3rd. Nothing. Octy goes well enough but the sound has always been disappointing.
Phil
Possibly because the compression ratio is much higher in a diesel?
Sent from my GT-I9300 using Tapatalk 2
