just got a vagcom cable
Ok, so I got a orange spring light on the dash and limp mode a month ago. Pulled over and when I restarted, all was fine and has been since.
I got a diagnostic reader off of eBay, but it would not read the car, so I got a vag com cable. I have done an autoscan and most is okay.
The log is as follows (apologies for the odd formatting on pasting with a tablet device, I have tried to show the faults)
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK
0000
08-Auto HVAC -- Status: Malfunction
0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK
0000
19-CAN Gateway -- Status: Malfunction
0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK
0000
46-Central Conv. -- Status: Malfunction
0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 EL HW: 03G 906 018 EL
Component: R4 2.0l PPD1.2 9802
Revision: --H22--- Serial number: SKZ7Z0F3775762
Coding: 0000072
Shop #: WSC 23042 576 94337
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 73430 790 00000
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004366309
Coding: 01880F030004140000110D000000000000087F075C
Shop #: WSC 24064 210 13409
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00063477
Shop #: WSC 24064
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0NT71N
Coding: 0020788
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenks?ulenmodul 035 0070
Coding: 0000012
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 E HW: 1Z0 920 942 E
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0F3775762
Coding: 0003401
Shop #: WSC 25061 210 91849
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068080088
Coding: 3D3F034007001303
1 Fault Found:
00469 - Infotainment Databus in Single Wire Operation
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 142088 km
Time Indication: 0
Date: 2000.00.00
Time: 16:11:31
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VD1 1612
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 01801A085283007F3F04050FC0085F96907C00
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Time Indication: 0
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 184799 km
Time Indication: 0
Date: 2000.00.00
Time: 15:10:33
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Component: Tuer-SG 005 0944
Coding: 0000756
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3F0048320
Coding: 0000402
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End ---------------------------------------------------------------------
I am not a mechanic, but air con, stereo and alarm horn (all of which seem to work ok) wouldn't cause limp mode would it?
Have I not done the scan right, or have I missed something?
I am v new to this Vagcom. I am not planning any major works etc, but would like to know what is up when the lights go on the dash. How can I see the error that caused limp mode and the dashlight a month ago? I want to check it is all okay and happy.
Jamie
sent via Playbook and Tapatalk
Every time you cycle the ignition the ECU goes through a self check,and then starts monitoring the various systems on your car. If a fault is deemed to be a "glitch" and does not reoccur over a set time then it can,not always depending on the severity and type of fault detected be dropped from the memory. Most things that effect emissions are stored and most things that will drop the car into limp home mode and put the fault light on are stored but its not a perfect rule.
Also what software version are you running i am guessing an older hooky version if purchased from Ebay???
0000
0010
0000
0010
0000
0010
Coding: 0000072
Readiness: N/A
Revision: 00H11001
Coding: 0006786
1 Fault Found:
Coding: 00063477
Shop #: WSC 24064
Coding: 0020788
Coding: 0000012
Coding: 0003401
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 142088 km
Time Indication: 0
Date: 2000.00.00
Time: 16:11:31
Coding: 0000756
Coding: 00000000
Shop #: WSC 73430
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 184799 km
Time Indication: 0
Date: 2000.00.00
Time: 15:10:33
Coding: 0000756
Coding: 0000402
Coding: 0000144
Coding: 0000144
Jamie
Just curious to what eBay Vagcom lead did you buy link would be appreciated
how do I tell if its dodgy? the diag was ebay, the cable was amazon...
MODERATOR REMOVED LINK
the disc came with several different ones. I tried one that would not talk to my canbus. in the end I am using release 908.0
That's a knock-off cable - surprised to see Amazon supporting its sale. I bet it came with warnings about not connecting to the internet to update it as it would lock out. Sign that the software has been hacked.
Sign its dodgy? Not paying the full £250 VCDS price is a pretty good clue first. ;)
Just reported that Amazon page to Rosstech shocking that its actually being shipped by amazon themselves.
no, no warnings etc at all. the seller was called ‘xxxxxxxxxx', who I thought was the supplier. £250! I thought I had bought a top end one, as it was more expensive than the ebay ones....
Edited by Gizmo68
Sellers name removed
The only genuine suppliers are listed here: http://www.ross-tech.com/distributors.html
If it didn't cost near £250, its a fake. I wouldn't personally let a hacked version of the software write to my car, that could cost far more than a real cable.
Still saving up for mine, though.
Just read all the reviews and they seem good for what I need it for its a bargain at that price ordered ......
Which one ?? The Amazon link ?
The only genuine suppliers are listed here: http://www.ross-tech...stributors.html
Cheapest option is around £210 for the CAN version
So you've potentially saved yourself a couple hundred quid (for now) and you're happy to plug a cable with software thats been messed about with , from an unscrupulous source into your pride and joy ?
You must be brave
You must be brave
One has to wonder what "support" will be given if it screws the car up.
Or what will be said if it's found that there is an issue and and update is needed.
Such bravery could well be rewarded with a bricked car.
At the price a genuine fully up to date with back up cable costs its a no brainer. We tried to code in a towbar module on a spanking new Jetta a while back sent a log file off and within 3 hours BOSH new update allowed us to do it now thats service.
It makes me wonder how this can be done all with no subs and the threat of cloned cables pinching food from their table.
so please even if it takes a little more time buy genuine and have confidence that it will do the job safely and properly.
Gentlemen, thank you for the support comments. We do appreciate your support for our genuine products.
As to Amazon, believe it or not, they are more difficult to deal with in getting the clones off their sales than eBay is.... Huh? Yeah, go figure. Seems all they care about is the almighty buck and they also figure they are big enough that our threats to sue are idle threats.... they'll find out eventually.
And then they will plead, "we didn't know..." the Nuremburg defense.
Ah the joys of having a good product!
Bruce,that is probably THE understatement of the year. The VCDS package is awesome,i have Dec,Bosch KTS,Launch amongst others and VCDS not only out performs them in many many ways it also has no yearly update costs!!!!!!!!!!!
Not wishing to cause any issues here but all the people who i have talked too and about VCDS in my area would gladly pay for updates as the tool is simply the best goodness knows what it's potential could be with more investment?
So from my point of view i will gladly shout from the rooftops about your product and at the same time condemn anyone who buys a cheap cloned copy. Keep up the good work.
laldog, we certainly appreciate your understanding but many still feel what we do is "too expensive". We preach value... but value is relative to each person who considers the buying equation. Sadly many do not see the value you see because they do not have the other tools and they want something for nothing. "After all, all I want to do is read codes. Why can't you make a lower cost unit just to read codes." and on and on.... Our goal is to remain the best bang for a quid one can get.. was that Brit e'nuff mate? hehe
Edited by bearthebruce
Ha ha yeah nice touch! I understand what you are saying and you are always going to get the i can get it cheaper at all costs types.
Just one thing though,make a bluetooth version and i will have your babies!!!!! Ha ha.
Just make sure you are prepared for that!!
HEX-NET
Thanks for posting that Gizmo... and laldog, I don't think you want my babies... little bears running around? really?
It's good to share some laughs once in a while... rather than tears... thanks for making my day guys!
