PD130 Rear Disc Size?
What is the correct size rear brake disc for the 1.9 TDI PD130?
ECP give me the choice of two sizes:
232mm
or
239mm
Which one do I need?
Mine were part 104440748 (232mm) last time I ordered and they are fitted so correct I presume, don't recall 239mm being a choice, seems to be now though, so you'll have to measure/ask I guess.
And blimey the prices have gone up!
FWIW Haynes says all diesels had 232mm rears.
Nice, I will order the 232mm this weekend. It's service time.
Just need to decide what I am doing with the fronts. Anyone know if Golf V5 callipers fit?
the 239 are 4x4 solid discs,232 everythingelse apart from the VRS which has 256 vented.If your fronts are 288 then the carrier only is needed to fit 312 from the VRS,Golf V5 is likely to be 312 so you would only need the caliper carrier. if you have 280 front the whole setup is different and you would need the whole V5 setup
HTH, Dave
Saying just get the carrier is alright, its finding someone selling the things separately. I could just get bigger discs and the carriers but I cant find any carriers for sale.
