VCDS not connecting
Please advise on how I can fix an issue connecting to my car. It's a 6K SEAT Ibiza , I can't connect.
Edited by posterboy
Find and fix the short to ground in the K1 line... you are going to have to trace the wires to do so. Multi-meter and lots of probing.....
Bruce, please enlighten me, what is K1? Is K1 hard wired and is this issue a problem with the car?
K1 is one of two diagnostic communication lines that run between controllers and out to the diagnostic port. Your interface is telling you that K1 is shorted to ground which means the tool cannot communicate with the controllers and it may mean that controllers cannot communicate with each other.
Yes it is wired between the controllers in the car and the diagnostic port. You will need a wiring diagram to find and troubleshoot the problem.
Edited by bearthebruce
Have you had an aftermarket radio fitted or any other work to the car recently???
Aftermarket radio is the usual cause
This is an EOBD wire diagram.
Thanks for the reply. No after market radio fitted. The car is bog standard. Any thoughts?
Yeah as stated before the tool is telling you you have a short to earth on the K line,you will need a wiring diagram to use and follow the cable from the EOBD socket to the ecu if this is beyond the realms of your skill set ( and i am sorry i do not mean any offence) the other thing you can do is cut the K line and run another wire from the ecu to eobd socket even as a temp measure to see if you get comms back.
Full car details,including age,engine size etc would help too.
Thanks very helpful,
it's a 6k SEAT Ibiza 2000 TDi , AGR engine code
Your wire runs from the dlc pin 7 to pin 25 grey/white through the dash then onto the ecu pin 11 dash to pin 6 green/black wire.
Many thanks, can you please tell me where you saw got this info?
You would find that information in the factory wiring diagrams for your car. These are available at the erWin.skoda website: https://erwin.skoda-auto.cz/
  • 2 months later...
Don't know if its the same issue I had with my sons ibiza
To fix the issue I removed the radio and this solved it, then found easier way was remove radio fuse and heater blower fuse then diag works perfect no short on k and was able to erase the errors then put the fuses back in
Hi PJ and welcome to Briskoda :)
Was it the original factory radio or an aftermarket one? It seems that some of the Quadlock to ISO adaptors will misroute a cable or two. (There was a posting in the ICE section where someone was using the wrong wire from the car side to try and trigger an amp.)
it was all stock radio etc, I the control unit has failed so will try a new one soon, however my work around was good
enough to reset the engine management light after I replaced the lamda sensor
