Disc Brake Dash Light....
Can anyone tell me whether the brake pad wear indicator on the instrument cluster is activated by making a circuit or breaking a circuit when the pads are low.
What I'm trying to work out is if I replace my pads without a sensor in them, will the light show on the dash????
TIA
well, surely thats an easy one? If you diddnt need a sensor they wouldnt have one ?
So if you want the warning light to work, use pads with sensor. If you dont want it to work, use those without.
No, it's a perfectly sensible question. As I understand it, all pads with a sensor rely on a "U" - shaped wire embedded in the pad which is broken when the pad wears down to the top of the "U". So if you fit pads without a sensor, the car's system will think the circuit has been broken and light up the indicator.
Yes pads without a sensor will light the light. You can short the connector (about 4 inches further up the loom) out with a loop of wire to turn it off again.
Thanks Gents,
The last pads I changed that had a sensor in had a single wire with a plastic end that when the pads wore down, would wear the plastic off and ground to the disc.
Obviously things have moved on since then.
:thumbup::thumbup:
Good grief, never thought of that. So it could be either breaking a circuit or making a circuit . I hereby withdraw my previous post. Someone must know which applies to an Octavia...
