Weitec Spring Distance Kit
Hi. I live in Kenya, and due to our road conditions I wanted to raise my Octavia Tour slightly. From the net, I came across the Weitec Spring Distance Kits that lift the rear by 20mm and the front by 15mm. I was also considering changing my tyres from 205/55x16 to 215/55x16.
Has anyone fitted this kit ? Or used this tyre on their Octavia 1 ?
Thanks for your help.
These are generically known as ring spacers
You should have no problems using them
Well known & respected method of tuning ride height without affecting spring or damper rate
Used extensively in the racing and offroading communities
Cheers !
