P1296 fault code help!
Hi em light came on other day had checked came up with p1296 coolant system maulfunction. Reading on internet it was pointing towards coolant temp sensor. Had replaced 80miles later back it comes. Has anybody got any idea wats next? I did read about the expansion tank? Cheers jonathan
thermostat
Hi, would thermostat cause em light to come on? Im sure temp ok thanks
This is Ross-Tech Wikii's decode of P1296.
http://wiki.ross-tech.com/wiki/index.php/17704/P1296/004758
Did you fit an OEM dual temperature sender or an aftermarket one?
PS. I suggest that you repost your query in the Octavia I forum where it will have greater visibility.
Thanks for reply, not too sure it was was from a proper vag supplier was a green 1. Any ideas wether thermostat would throw light on?
