Help with fault code
I've just done the first scan of my brand new vRS estate and one fault was found in Cent. Elect.:
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H28 0555
Revision: -1------ Serial number: --------------
Coding: 25980B3808C92400922808002C2B08C000C0420F60000000020000000000
Shop #: WSC 13765 790 00018
VCID: 4E952B1A19BE0A68E30
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3211
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 H05 1501
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Coding: 810000
1 Fault Found:
03156 - Sensor for Anti-Theft System (G578)
004 - No Signal/Communication
Does anybody know what the problem could be? Should I just clear the code and see if it reoccurs?
Personally I'd take it back to the seller and say the alarm doesn't work.
Clear it and see if it comes back, if not then all is well.
Yup that seems to be the problem. Just noticed that the central locking LED is staying on for 30 seconds after the car is locked. If I temporarily disable the internal sensor with the button on the driver's door, the LED starts flashing straightaway. I'll check the connection on the ultrasonic unit and if that doesn't work it's a trip to the dealer.
Sent from my iPad using Tapatalk HD
The Skoda manual says this:
Indicator light in driver's door on vehicles with anti-theft alarm system
After locking the vehicle the indicator light flashes for 2 seconds fast, then more slowly.
If the vehicle is locked and the safe securing system (page 45) is not operating, the indicator light in the drivers doors flashes for about 2 seconds fast, goes out and starts to flash slowly after about 30 seconds.
If the indicator light first of all flashes for about 2 seconds, afterwards lights up for about 30 seconds and then flashes slowly, there is a fault in the system of the central locking or interior monitor, (page 51). Visit a specialist garage to obtain assistance.
Edited by PompeyKev
It was indeed the ultrasonic unit - all is now well.
  • 2 years later...
what exactly you changed < that the error was gone ?
03156 - Датчик охранной сигнализации
            004 - Нет сигнала/связи
             Стоп-кадр:
                    Статус неисправности: 01100100
                    Приоритет неисправности: 4
                    Частота появления ошибки: 1
                    Индекс забывания: 19
                    Пробег: 86003 km
                    Отсчет времени: 0
                    Дата: 2016.02.14
                    Время: 03:10:35
             Стоп-кадр:
                        Кл.15 ВКЛ
                    Напряжение: 11.60 V
                        вкл
                        вкл
                        Кл.50 ВЫКЛ
                        выкл
                        выкл
Mikez hasn't been online for almost a year so you probably won't get a reply.
You should make sure that the ultrasound sensors for the alarm sensor are plugged in. At least on a MK2 Octavia these should be behind the three vents in the sunglasses holder or blanking panel next to the front interior light.
If they are connected and clean, you might need to replace the module assuming the wiring is correct and undamaged.
I took it into the dealer (with it being a new car) and they replaced the ultrasonic unit. Twice, in fact, because the first replacement was faulty, too, and showed exactly the same symptoms within 2 days.
I then just cleared the fault in VCDS.
Still lurking now and again :)
