Can I install XP pro on top of XP home?
Running a PC I bought from another Brisky all is well but it has XP home installed and I want to upgrade it to XP Pro so I can attach it to my domain servers.
Both versions of XP are official.
Anyone know if I can install XP pro over the existing installation of XP home or do I have to flatten it & start again?
Regards, Mike
Flatten it.
Job done with minimal fuss.
+1, but check to see if you need any other drivers ( graphics card/ motherboard drivers such as Lan etc, AND AVG ,antispyware etc) and download them to an idepeendant place ( usb drive etc). Then at format time, full NTFS format ,to eliminate any nasties on HDD.
Probably will upgrade but a clean install in normally a time saver in the long run.
and also gets rid of any nasty pron they may have left on it. :happy:
XP Home can be upgraded to pro with no problem, just insert the disk and upgrade.
XP Pro cannot be converted to home, since it is not possible to upgrade to a lesser version.
As I remember, there is VERY little difference between XP and XP Pro, just a few network/security management tools; certainly not enough to justify the huge price difference.
Remember, there is only 1 year before M$ stop all support and updates for XP; maybe you should think of installing Win7 on your network while it is still possible to find the licenses.
cant run a iis Server on home :think:
Weren't most of the differences simply hidden in home, and can be accessed with a little know how?
Good advice & well taken. Thanks!
See new thread on 32 v 64 win7
Couldn't join home to a domain though, so not much use in a business environment. :)
