running wires through car? Best way? Help needed
So I am fitting air suspension this week and wanted to start by running the wires up through the car, I have a sub fitted to the car but I never fitted it, I can see the wires run up the driver side of the car but not sure where to start with the removing??
I am guessing the front drivers seat would be a start but has anyone fitted the likes of a sub woofer as it will be the same thing running sub wires up as air suspension lines??
Just a quick guide what and where to start,
pull drivers side rear seat back forward and there are some torx and a nut on the plastic trim which just pulls off on spring clips all the way to the front (not sure what secures it at the front) and there is a channel in there which all wires run down..... i believe there is one the same on passenger side too not 100% sure
I routed some of my cables up the A pillars, under the edge of the headlining and down into the boot. Very easy.
Thanks, got that done Just cant get the plastic trim around the bonnet pull level, any ideas??
Also if someone could clear up if theirs one running up the passenger side too??
Also where can I run the power lead through to the battery??? My sub/amp is just wired in just to the right of the steering column their are a few power outputs their im guessing? see picture below..(brown/ gold coloured wire)
Another idea might need to do this too allot of wires to get to the front to run/ control the air suspension.. Thanks
behind the glove box there is a huuuugggeee grommet when you can run loads of cables / airlines through and im sure i read in another thread that there is a channel under the passenger side trim maybe worth pulling it up a little at the back where its easy to double check ..... if your running wires from engine bay i would defo try to keep it all on passenger side if poss
