Gear whine on deceleration
Hy guys would like some opinion I have a 57 plate vrs and have discovered it has gear whine only as far as I can tell on deceleration and only in 1st or 2nd gear it doesn't do it from cold well not that I can tell but after the car has warmed up and I am concerned?
Any thoughts or recommendations are most welcome
Get the gearbox oil changed see if that makes a difference.
Have you had or considered getting the oil changed in the transmission ?
george
Using the correct gearbox oil when changed has cured a lot of problems with cars on here :)
Guys that's fab I'm looking to get a service done ASAP as the last service was the cambelt change at 55k now on 64k
How much does it cost to have transmission oil changed?
I was quoted £40
Nice one grizzle ill get it changed when serviced and ill report back cheers for the help
  • 5 weeks later...
Grizzle where were you quoted £40 as I've been quoted £108?
Quite a simple job to do yourself, there are plenty of tutorials on youtube (mainly on VW cars but essentially the same)
£108 sounds expensive to me, have you tried an independent garage? Although £40 might be too cheap.
  • 1 year later...
Thread revival! I've just bought a 57 plate vrs that does the same. Is it just a common whine on these that causes no harm? Or have people quietened there's down by replacing the gear oil? Thanks Olly
This is quite common on these gearbox. I have posted similar question some time back nothing to worry about.
Perfectly normal; especially first gear. Mine has done it for 3 years with no issues. It's actually louder since I fitted an uprated dogbone (gearbox) mount.
I thought this was a normal gearbox noise. Glad to see its nothing to worry about
Sent from my Galaxy S5
