new exhaust causing limp mode?
new to this forum, always get answers from old threads but cant find any1 with my current problem.
i have a 2006 octavia vrs tfsi, just had a custom catback exhaust with silencer removed from zorstec in bradford, very happy with the looks and sounds but it goes into limp mode every now and then, no dashboard lights come on but only revs to 4000 rpm then other times its fine just wondered if any1 had similar problems? going to get vag com on it if i can get hold of it.
cheers for your time
jay
Just a cat back exhaust shouldn't do anything, like you say get it scanned and go from there
cheers trev, it seems to be ok now but itd be nice to know what it was, just did it since i got the exhaust fitted this morning, never done it before, i have a forge dumpvalve spacer n its got really loud since exhaust fit aswell is this normal?
I'd never run one of those spacers, I've heard of a few running issues due to them.
yeh get the original DV back in.
I've had my spacer on since end of last year havent had any problems yet,
There were a few issues like this ojn Mk 1 octys when tuned, the Lamba was being tripped up & needed spacing back slightly to smooth out the reading. It would often happen after the car had cruised gently for a while , say in a long 50 section of roadworks & rthen given a good right foot aplication at the end
This may help http://www.briskoda....er#entry1503734
I used one something like this http://www.ebay.com/itm/L-SHAPE-O2-OXYGEN-SENSOR-90-DEGREE-ANGLED-BUNG-M18-X-1-5-SPACER-EXTENDER-/130842801178?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e76d6b41a&vxp=mtr but check it fits your car
Edited by Stuart_J
Maybe if the op had changed the downpipe, but as its just the cat back it's all downstream from them so should have no affect
Exhaust won't cause this issue unless they have some how damaged rear lamda but I doubt it
Get it scanned
cheers for the replies, for some retarded reason i will never know why but i asked for a 3 inch exhaust and he fit a 2 inch :/ who goes from 60 mm to 50mm! anyway hes fitting a new one next friday so hopefully it will run ok then, only problem is im getting it remapped tomorrow morning so will need a tweak when i get new exhaust
thats why i got a milltek in the end, had a custom exhaust, that was 2.5inch but wasnt mandrel bent so it places it reduced to around 2 1/4, lucky i got it second hand other wise i wouldnt have been happy. Millteks are 2.75inch :)
cant you cfancel the remap ??
taking it for remap tomorrow, hes goin to tweak it when i get 3 inch on n put it back on rolling road for free :) whats stage 1 like on a vrs tfsi?
