Vrs info
Going to look a vrs close to me tomorrow, the girl said she had the assenger airbag turned off due to her kids babyseat in the front. Is it easy to turn the light off/ re enable airbag on vagcom?
I'm sure it's done with your car key inside the glovebox mate
I can't remember there being a key slot in my old vrs glovebox. Just the knob to turn on the cold air??
Key in glove to turn mine off. Easy enough to check when you have a look at it.
Nice one, ill check it when i see it. If it doesn't turn off why else could it be on?
Just saw that the switch was an optional extra :/
It was, my old vRS had it. If there was a warning light above the radio
where the rear screen button and ASR/ESP button are then there will be
a keyswitch in the glovebox.
If it doesn't have the key switch in the glove box (my 2006 elegance doesn't), it's very easy to turn it on/off with VCDS.
It was something you had to spec
