Tyre pressure ministering system
Thinking of replacing my standard vrs alloys with something more exotic so my question is.. What do I do about the tpms? Do I have to transfer the sensors to the new wheels or is there something else I have to do?
If it helps my car is a 06reg octavia vrs petrol
don't worry about it
check the pressures and reset the system - press and hold the (set) button till you hear a beep
Also can u swap front alloys with the rears and not have any errors ? Need to replace the rears but want to put the current fronts on the rear and replace the drive wheels with better rubber as the current fronts are n
There is no sensors inside the wheel, the system works by the ABS ring, ie. if the tyre stars to go flat the rotation of the ring will be faster than the others. thats how it pick up flats/punctures.
This +1 is the info the op needs
Wtf is ministering?? Does the system conduct a sermon for your tyres??
:giggle:
Cheers guys, sorry for the bad spelling. Thank good old auto correct on my iPhone
An option on the Octavia Vatican Special Ed?
Dearly beloved, we are gathered here today, in the sanctum of the Ocatvia to advise you that one of your tyres is a wee bit slack.... :rofl:
