picture request. 35mm h&r springs
Managed to snap a spring on my vrs tdi.
Obvious replacement is fitting the h&r 35mm springs. I know these will only drop the car 20mm.
Does anyone have pictures of their car before and after fitting. Side profile if possible.
Also have they actually lowered the car 20mm or it more / less.
Tried searching but not getting the pics I am after
Much appreciated. Neil
Here's my old vRS,
before picture is on standard suspension
Here it was before:
After, this is fitted with H&R shocks and 35mm springs, it does lower it a bit, but I ended up changing to the 45/50mm springs to get it sitting better, although you need to get H&R dampers when going 45/50mm as they will wear out your standard shocks in no time.
