Hid beam pattern
Just seems to be that since I've fitted my hids the beam pattern seems to be a little out what do you guys think??post-99492-13647028080715_thumb.jpg
Yes, the aim looks very low campared to my factory Xenons.
Easy to adjust though.
Looks very low. As Booke23 says, it is adjustable and there is a fairly recent thread, but check the dashboard beam adjuster first.
Next, have the H/L units have been reinstalled correctly. I had some paint work done and the bodyshop didn't get them right - looked ok - but I got a couple of flashes and a check found the N/S not seated.
If you still find them too low, check the "bulbs" have been seated properly. There has been a thread or two about HID's being installed incorrectly.
I have faced them down to get a aspect on how they are aligned they are usually on the 1 setting inside the car but the left beam seems to be a little higher then the right not sure
