Dump valve spring
Hi
Installed my new dump valve at weekend. Purchased off eBay item number 251099867404 it's a mk1 octavia and has been mapped but not sure what bhp? The car has not had anything else modified so I just left the blue spring supplied. Will it make any difference and are they ok valves? New to vag 1.8t engines but know to avoid atmospheric ;-)
If it has no other mods then it will be a stage one which is usually around 205-210bhp, but you may want to get it in the rolling road to be sure. I think then u will need the medium spring in the valve, I'm not sure what colour that one is on that valve.
Think it's yellow one. You get 2 spacers too but not sure if u need to put one below spring?
Hi
I would first run with blue spring and see if that runs ok and holds boost.
You will soon know.
If not go for yellow spring.
Forge colours are:
Green
Yellow
Red
Green being softest
Think yours are:
Blue
Yellow
Red.
Blue being softest
You should not need mapping just by swapping a DV and spring.
Sent from my Galaxy S3.
You will soon know.
Forge colours are:
Green
Yellow
Red
Green being softest
Think yours are:
Blue
Yellow
Red.
Blue being softest
Seems to be running on with blue spring. How do I know if its not holding boost?
