vrs vacuum hoses
Does anyone know where you can get replacement vacuum hoses for the vrs? I just need to replace the thin plastic sections that fit inside the chunky rubber hoses. I've tried googling loads, but just comes back with diagrams, forum results or the chunky rubber stuff. I might have to try and ring a couple motor factor places tomorrow or even skoda if I have to.
Just use silicone boost pipe
Ok will do. Does the different diameters not make a difference? As the plastic pipe that I need to replace is loads smaller than the silicone stuff it fits in to
As long as its a tight fit with no leaks should be ok
Which pipes do you need? I may have them. Pm me a picture or something.
Ffs sorry mate only just seen these replies. I've ordered some off Ebay now, hopefully that'll do the trick. cheers anyway
