Is there a rear shock fitting guide for the VRS?
True. In general though
Ratchet spanners are just as handy really
Ratchet spanners can't get on to the nut, as the nut does not protrude from the strut. The disadvantage of a gear wrench (Vortex, etc) is that it's not available as a torque wrench.
The correct tool to use is an open-sided socket. The socket goes on a torque wrench and you counter-hold the strut rod with a hex key. These are what VAG techs use.
True , nice post, is there a link for these as they don't seem to be readily available
I used a sparkplug socket, a rachet spanner on that and a thingy though the top of the socket lol
Sent from my GT-I9300 using Tapatalk 2
Those are VW ones and they may be available from a dealer. I'm sure Snap-on will do similar tools.
The 21mm for the front is VAG tool code 3186 (Hazet 2593). Aftermarket struts often use 22mm top nuts, but as we always replace them with 21mm VAG top nuts, this is the only size we need.
The 16mm for the rear is VAG tool code 3379
You also need VAG counterholding tool 3079 (does 5mm and 6mm strut tangs)
There is a combined tool for the rear (VAG tool code 30179A) but I prefer to use the separate tools
IIRC, some of the Golf Mk4 boys have used a Duratec injector socket such as http://www.ebay.co.u...M-/390542986449 for the fronts. I've not tried one myself, but they look as though they are good for 60Nm.
I just clammed my hands on to the strut whilst my friend undid the nut haha!
Wasn't able to do that on the fronts though!
Nice information there buddy.
I was looking at this.
http://www.ebay.co.uk/itm/US-PRO-1-2-Inch-6-piece-Thin-Walled-Diesel-Injector-Removal-Sockets-Open-Sided-/281072857129?pt=UK_Hand_Tools_Equipment&hash=item41713f7029
but a bit steep considering i have the Proxxon socket set already and although can't torque, fit's most of my needs
Any ideas what the inner strut nut size is. not sure that is 21mm. My KW's use 22mm top nuts
JESUS.... fecking gorilla hands!
lol, no he left them where they snapped off in the springs... :rofl: .
sorry bouncy was the wrong description, what I meant was smoother, not as harsh as it was before : )
