tension adjuster failed
hy all
has any one had a aux belt adjuster sheer of the engine, my problem is how do you remove the broken bolt, no room to drill it out,might get an angle drill in to do it,only got 4" room between chassis and mounting bracket. any other ideas.
thanks
chas.
Posibly might have to lift engine out.
can you drop the top engine mount and get at it from the wheel arch?
