TYRE DATA
My little one uses 185/60 /14 tyres . SIL has aquired a pair of new 185/65/14 on steels. Almost new. any problems on fitment . ?/performance .
The 185/65/14s will have a larger rolling circumference that will make your car higher geared and will make your speedo under-read compared to the standard 185/60/14. Clearance should be fine (assuming the wheels are the same fitment - PCD/centre bore/offset) as they're virtually the same (within 1%) overall diameter/circumference as 205/45/16s as fitted to the vRS. Don't forget to notify your insurer if you decide to use a non-standard tyre size.
