RARB Question
Fitted mine the other day. I did drop the car onto its own weight to do up the bolts into the shocks.
Anyway when I go over bumpy ground it's like there's a loud creaking noise coming from the rear. Is this what I have to put up with or have I done something wrong?
Should I have lubed up the area between the bush and rear beam?
I did stick some copper grease on the actual bar before putting the bushes on.
Mine started to creak yesterday after changing my bushes. Not sure if its just a case of more grease on the bushes though. It might help mate :)
It's something I could try, I'll be under there fitting my new coilies next week anyhow so it may be worth a try :)
Awesome let me know how you get on with the aps :)
It will be the bushes need greasing for sure.
Will let you know Charlie, can't wait to get them fitted.
Thanks W8 will lube them up some times next week :)
Agree bushes Moar lube needed :D
