My mirrors have a mind of their own!
Hi Folks,
About a year ago, my Yeti developed a peculiar fault which only occurred twice, but if you switched the ignition off & on, (rebooting!!) the fault disappeared. Yesterday, it did it again, & now, once more all is well. How can the dealer find that? Anyone here had similar experiences? No warning lights on either. Here goes...
When you select "L" on the electric mirror adjuster, the passenger mirror responds just fine. But when switching to "R", the driver's side mirror doesn't move, but the passenger one moves again instead, & in the reverse sense! What's going on here then? & as I say, if you turn off the ignition for 10 seconds, it all resets back to normal. The heating & folding functions work on both mirrors (including folding them from the key fob with the 3 second press of the "lock" button)
Damn Multiplexed electrics! What's wrong with a switch, a wire & a (simple) gadget?!
I can see this developing into one of "those" dealer scenarios! :wall:
I suggest this might be better posted in the "General" Yeti section, you may get a better response to your question there. :hi:
The technical guides section is normally reserved for Technical information and "How to" guides.
Oh ok, ta for the reply, but I thought as it was a query about a technical problem, it would be better here. Now I just need to try & shift it!
This area is for Technical Guides.
I have asked the Mods to move it.
