Tfsi coil cable tidy bandits
A pair coulda had your name on
I want , I want....
Function over form indeed. Think I sold em for a fiver to cover my costs and time!
I want , I want....
Hehe
I'll try get part numbers to u ;)
Pm'd mark ;)
So whats any issue with the tfsi cover but ?
It looks like more of a cable tidy/hide away rather than an insulator/heat reflector :(
Its is :D
It is as per op title buddy.
The comment further down relate to heat shield which you can't fit both.
Sent from my Galaxy S3.
So aslong as pete dont melt his i should be fine
Is it worth leaving the heat cover on my blue elbow hose behind rocker then just to be safe
heat shield defo needed on these things as said my old coil loom was brittle cracked on outer cracked on inner was pretty shocking :(
no heat issue?
No heat issues at all with the wrinkle paint, its rated for about 170c. If you put heat to it after painting it make the wrinkles tighter. Some people put it in the oven after it semi dried.
cool i shall look into it
cheers dude :)
