Retrofit Hill Hold Control
From the Drivers Manual for my March 2012 Octavia.
Uphill Start Assist*
The uphill start assist makes it easier to start off on steep hills. The system assists a start
off by holding the brake pressure produced by the brake pedal actuation for approx. 2
seconds after releasing the brake pedal. The driver can therefore move his foot from
the brake pedal to the accelerator pedal and start off on the slope, without having to
actuate the handbrake. The brake pressure drops gradually the more you operate the
accelerator pedal. If the vehicle does not start off within 2 seconds, it starts to roll back.
The uphill start assist is active as of a 5 % slope, if the driver door is closed. It is always
active on slopes when in forward or reverse start off. When driving downhill, it is
inactive.
The car must be fitted with an inclination sensor for the car to 'know' whether the car is on a 5%+ slope.  My car has an inclination (tilt) sensor for the alarm, so I assume it is dual purpose.
  • 9 months later...
  • Replies 64
  • Views 20.7k
  • Auric Goldfinger
    Auric Goldfinger
    Stop on hill, select " N " hand brake on, foot off brake, when one requires to move select " D " , slight pressure on accelerator and release hand brake. Simples :yes:
  • Auric Goldfinger
    Auric Goldfinger
    I've got 2 feet
  • hill hold probably can be enabled http://www.myturbodiesel.com/1000q/a6/hill-hold-disable-vw.htm folding mirrors are possible, finding cheap parts is the problem. new parts = £1200
I now have Hill Hold on my Vrs
Can this be done on a pre FL 6-speed DSG?
It already has ESP.
depends on what pump you have
I guess the only way to tell that is scan it with vcds or open the bonnet and check the part no?
do a scan with vcds
According to VCDS, part no is 1K0 907 379 Q
This is the full scan for ABS:
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 73430 790 00000
   VCID: 408ADCBB13BC921EDBD-8015
No fault code found.
When I bought my Octy the rear brakes were binding, I thought I had hill hold for a couple of days!
I suppose you lot want a fully automatic car in the end, just jump in your personal conveyance, tell it where to go and voila.
We already have them...
They're called taxis! :-)
So can it be done just with coding? Or would the pump need to be changed?
If you don't have a HH pump, you need a new pump. I looked into this myself when I had an Octy 4x4.
My March 2012 MkII FL vRS TDi DSG definitely has Hill Hold.  I find it useful.  With my car a firm application of the footbrake is necessary to invoke the Hill Hold; if just light pressure is put on the brake pedal the Hill Hold is not activated.
So it seems the previous owner of my car had it modified to fit/enable Hill Hold.  Or was it an option on the vRS in 2011/2012?
  • 6 months later...
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B401C092300FA881202ED902100426C00
   VCID: 74C9129DD7A00E9
Is it possible that this one has sensor for HHC?
I had an option in quote when I bought a car but did not want it then :(
huh... :-)
tnx for very fast answer.
Kiko
  • 6 years later...
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AQ    HW: 1K0 907 379 AQ
   Component: MABS MK70M          0105
   Revision: 00H32001
   Coding: 0000257
   Shop #: WSC 73430 790 00999
   VCID: 014157041986D8C95D-8054
My module don't support HHC maybe ? What I need to do to retrofit this function ?
   Revision: 00H32001
   Coding: 0000257
You need to retrofit a suitable MK60EC1 module. It will involve rewiring/changing the ABS module connector and adding an extra power feed.
You'll also need to create a suitable long coding which will be specific to your VIN 👍
