Slight thud/thump engaging gears Vrs tdi
The wife noticed a small issue the last week in traffic,when u engage first gear u can hear/feel a very slight thud or thump,sitting idle u can get it to do it in any gear slightly, otherwise gearbox perfectly smooth no issue at all, also this thud is there when car is hot or cold. If u go into gear slowly u can't hear it.
Iv never really noticed as I alway have clutch engaged in traffic.
I might change gear oil anyway.
Car is 07 Vrs diesel. 80k miles.
Anyone else heard this?
  • 7 months later...
What's the best gearbox oil and do I need 75w 90, fully or semi synthetic?
A dragging clutch perhaps...
Is the bite point almost immediately on raising the pedal?
If so I'd be inclined to bleed brake/clutch fluid and if symptoms persist have a mechanic look at it, maybe the master/slave cylinder seals are worn.
Deleted due to duplication.
Edited by billywhiz040480
I had a new dmf, clutch and slave cylinder in the summer and the clunky/notchy ness was there before so it can't be any of those.
It feels like a delayed engagement but only in the first two gears but not always.
