Flashing glow plug light
Ok, story is, long trip up M1, sat at 70 on cruise control.
Something on the dash caught my eye and when I looked down the glow plug light was flashing, this continued for about 10 seconds then went out and didn't return for the rest of the journey (circa 75 miles).
No other warning lights, no loss of power/limp mode or any signs whatsoever of a problem and happened after being sat on the M1 for around 75miles so car was warmed up etc.
I am hoping something has been logged when I get around to scanning it, but in the meantime does anyone have any ideas?
Car is a 2.0 pd tdi scout so has a DPF, but no DPF warning light appeared at any point.
Many thanks for any ideas.
Possibly exhaust pressure sensor?
My experience with this is this happened to me fr a little while, then eventually the engine check light came on and dpf... Ended up having the dpf removed and remapped but this didn't cure the problem.
Turned out the turbo actuator became faulty, the diaphragm in the actuator split, this then meant the turbo stopped working properly and the dpf ended up getting knackered because the car could not regen....
More than likely its related to your brake light switch. First thing is to check if your brake lights are working. I had flashing glow plug light a few weeks ago and even though my brake lights were still working the switch was on its way out as it showed up with a diagnostic scan. New switch sorted it.
Thanks for the replies, hope it's the break switch and not turbo/DPF as cant really afford a big bill.
I will get vcds on at the weekend and see what it says.
Quick update, this is the scan for the car:
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 SS HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 1302
Revision: --H08--- Serial number: SKZ7Z0H4763111
Coding: 0000172
Shop #: WSC 73430 000 00000
VCID: 820F4DABDD7E6108B78
1 Fault Found:
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 1
Fault Frequency: 2
Mileage: 150393 km
Time Indication: 0
Date: 2000.00.00
Time: 19:12:09
Freeze Frame:
RPM: 1785 /min
Speed: 93.0 km/h
Load: 0.0 %
Duty Cycle: 17.4 %
Duty Cycle: 95.1 %
Mass Air / Rev.: 270.0 mg/str
Mass Air / Rev.: 460.0 mg/str
Readiness: 0 0 0 0 0
So, looks like my EGR could do with a good clean out.
