Bolero display for air con etc se connect.
Now I have a 13 plate vrs with a bolero head unit and when you adjust the air con etc it displays on the screen of the stereo.
My dad has a 62 plate SE connect and after gettinng a lift home from the pub from him tonight it appears not to do this. Is this normal or is there anyway this can be done to get it displayed? it has a maxi dot display, could this be a way of changing the settings?
Mine has dual zone and his normal air con but i wouldnt have thought that would not make a difference.
I am almost sure that you only get that display if you have the climatronic and not with the standard heater and manual air con.
That said, the display is controlled from the Bolero - somewhere in setup you can change how long the climatronic info is displayed - may be on/off function in there too.
