2010 vrs drl problem
Hi everyone, I'm having trouble with my left side DRL, right now its off completely and I'm getting a message saying "check front left side light" it doesn't happen all the time, sometimes its on but then it starts flickering and other times its completely off like right now, any ideas would be much appreciated.thanks
Sounds like poor connection, or bulb. Change bulb from right side lamp and see if you get same problem, have had broken filament before and vibration on road made lamp work sometimes.
I had probs with the o/s drl on my wife's 11plate octy (non led) I changed the bulb and sprayed with contact spray and it seemed to cure the prob although I did mention it at the service and was told they were having probs with a retaining clip in the loom .
I haven't seen the part yet so can't tell you what to look for .
Might be worth a call to the dealer
Regards whoosh
Thanks for the responses, I'll have a root around when I get home from work and see what happens, thanks.
