What does this sound like?
I no this has been covered many times! my car is is going into limp mode, but it only does it on odd occasions and it is basicaly when i am at 60mph and accerate slowly in higher gear limp mode cuts in. But when i floor it at 60mph again it 4th and take it round the revs the car is fine. When limp mode cuts in I can switch the engine off and back on and its fine again would thas still be the veins sticking? Hope people can help as if it is a possibility i will do the mr muscle tip tomoro
Me no speak a no English.
Ye not helpfull realy
Well sorry to say it but your opening post wasn't exactly clear...
Try explaining it a bit better and someone may be able to help :D
C'mon it wasn't that hard to understand. Have you read the fault codes to see if anything is logged? It won't drop into limp mode for no reason so don't ignore it.
mr muscle is a proven fix try it tomorrow and feed back
Thank you i didnt have time to read codes today been busy at work first job monday :)
I had exactly this issue, did the MM trick, not done it since :)
Thanks buddy ive just gone and bought some 2day
