Octavia 1.6tdi cr revs phenomenon
Hi . Not a big deal but want to find out what's wrong. After each petrol station visit my car starts to keep the idle revs up to 1000 rpm, like engine worm itself in a cold days. It is happen for first 10-15 engine starts only. I can drop the revs down to normal by sharp touch the acceleration pedal. It is Skoda trick or something works wrong, any idea??? Many thanx
It´s the regeneration hapening, don´t end the process.
You should drive on highway above 2500rpm for a short period to clean the system.
No need to use the higher gear, use forth.
And do push 2 or 3 often and you will find that the regenerations are every 400-500km between
What system do you mean? DPF? It's happen with every single filling up
Try turning your fan off and heater down to half see what happens and let me know.
Does the fan related to the revs? ))))
It did on my car no reason why it should but revs dropped off when I turned fan off.
Hmmm, interesting ...
