I got bored :) (pics)
I started to insulate the doors and I'm very happy,music sounds much better,I won't get water infiltrations.
Looks much neater than my efforts :)
What are you using ?
It looks like silent coat,you get 2.5 mm or 4 mm.
Yes,is Silent Coat 2.5mm.I made a template of paper and then I cut the coat after the template.
I'm very pleased with the result.
Did you manage to get a good seal round where the wires for the speakers etc come out, I had a problem with water running down the speaker wires and out the bottom of the speaker and into the car.
Yes,I cut the coat near the wires to made it moulded ,had no problem,everything is sealed .
I made the other doors too on the left side.I runned out of coat,so I bought some STP coat,the say is supperior quality,but I can't see the differences.
Anyway...it doesn't look much but the results are remarcable,the cabin is much quieter,at 120 km/h (3000rpm) is so relaxing do drive,is allmost boring.The music sound very good,no rattle no noise at high volume,I'm impressed....I shoud done that years earlyer
Total cost was under 20 pounds,I recommend all of you.
Did you put any on the inside of the outer skin aswell?
Looks like a good tidy job!
no,I didn't
